1986 Mazda B2000
Discussion in 'Mazda Truck Forum' started by Bruce2, Jan 20, 2013.
  1. Bruce2
    Bruce2 New Member
    Jan 20, 2013
    I just got an old B2000. It will start when it wants to and die when it wants to. There's no pattern to it. It has a carb so it can't be a fuel relay, although that's what it acts like. I changed the fuel filter, no improvement. Any ideas?
  2. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    forklifts and equip tech
    Tupelo Ms.
    probably need to catch it in the no run situation and check for fuel and fire and determine which one is causing the problem.
  3. OldTruck
    OldTruck New Member
    May 6, 2015
    Just had the same issue. It usually started but would randomly die. Problem was the ignition switch. The contacts were pits would lose contact in the run position.
  4. MrMarty51
    7,272
    9,924
    Welcome to the forum Bruce.
    It has to be one of three things. Fuel, spark or compression, or, does the temperature gauge climb excessively high just before it shuts down ?
