1976 to 1985
Discussion in 'Chevy Truck Forum' started by bigun, May 8, 2013.
  1. bigun
    bigun Full Member
    May 10, 2010
    45
    I have a 1985 C20, 4 speed manual and looking to buy a 1985 K20 with automatic, not sure which trans I''ll use but will the body of the 85' be a direct swap to the 76'? I'm thinking that it is, someone please correct me if I'm wrong and any advice. thanks
  2. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    I would tend to think so but not 100% sure. Might have to make a few mods but I wouldn't think it would be to extreme.
  3. batty1214
    batty1214 Full Member
    Nov 2, 2008
    2,276
    510
    Mine Mechanic(tire guy)
    Vernal Utah
    I swapped a 78 onto a 84 frame for a friend once.. no mods needed.. so im guessing it'll be fine..
    If both are 2wd should be straight swap...also if both are 4x4 will be. Hump in the floor different on 4x4 from 2wd.
  5. bigun
    bigun Full Member
    May 10, 2010
    45
    the 76 is a 4wd my 85 is a 2wd but has a large hump for the 4 speed manual an already has the cutouts for the TC shifter, the reason for all this potential work is I need the 4x4 and the 76 body is trash, mines not and the 76 4x4 is only $900 running
  6. bigun
    bigun Full Member
    May 10, 2010
    45
    after thinking about it for the day, seems I heard someone say the steering boxes are in different places on 2wd than 4wd and did they make a frame change from 1977 to 1978? thanks for any and all help
    hmm did not know this i will search or maybe another member may..let you know tomorrow if we find any info..bigun
  8. bigun
    bigun Full Member
    May 10, 2010
    45
    Thanks, but the truck got sold before I could get to it, but I'll take any info cause I'm still looking, thanks again
  9. joeb
    joeb Member
    May 11, 2013
    Some fairly large mods to switch 2wd to 4wd in those years. Will have to cut change body in center, trans mounts, steering etc. Fair amount of fabrication work. It can all be done, just not a simple swap.
  10. buck2552jr
    buck2552jr Senior Member
    Sep 22, 2012
    71
    Grounds Keeper
    Oxford, Michigan
    If your getting a K20 i would go with a 400 turbo. If you put a decent rear end in the truck you will have enough torque to tear down a house as well as good speed :)
